  #1
Old September 11th, 2006, 10:54 AM
mkwpgca mkwpgca is offline
Default help starting 66 evinrude
I just inherited my dads old 66 Evinrude Fastwin 18hp, and am trying to get
it started after many years in storage. I've changed the oil in the bottom
end, removed and cleaned the carb, checked and regapped the plugs (they were
put in new when it was put away), and I put a little oil into the cylinders
before turning it over. It turns over fine, but will not fire. I've
confirmed it's getting gas, and there is spark, although I'm not sure how to
tell if the spark is "weak" or not. Even squirting a little gas in through
the spark plug holes won't get it to fire for a few seconds. After a few
hours of fruitless pulling and a very sore shoulder, I decided to put my
multimeter across the kill switch contacts, and found that there is
continuity between them. I've confirmed that the actual switch is not the
problem, as with the switch removed, there is still a short between the 2
black wires that lead to it. Before I jump to conclusions, am I right in
guessing there should be no short here? What do these wires lead to? I
always assumed the kill switch killed the spark, but since there is spark on
both plugs, I'm confused. My gut is telling me to order a "tune up" kit, and
replace all the ignition parts since they're probably original, but I'd
appreciate any advice from those with experience working on outboards, as
the closest I've come to working on these is resuscitating old lawnmowers
and snowblowers.
Sorry for the long post,
Mike Kayer
Winnipeg, Manitoba, Canada
  #2
Old September 11th, 2006, 11:21 AM
R.Johnson R.Johnson is offline
Default Re: help starting 66 evinrude
Those two wire's connect to the point's ground plate, so you would have continuity across the wire's. The ignition should fire across a 1/4" gap. After sitting this long, you probably have oxidized point's, or possibly age cracked coil's. The best route would be, look, and see.
  #3
Old September 11th, 2006, 11:32 AM
F_R F_R is offline
More than likely bad coils. They are famous for that. Agreed that continuity is normal between the wires. They attach to the points the same place as the coil and condenser do. Even if one set of points is open, there is still continuity through the coils' primary windings. That's why connecting them together via the kill switch works....it shorts everything out.
  #4
Old September 11th, 2006, 11:54 PM
Thanks for all the quick responses. I replaced the plugs (.30), points (.20), and condensers, now it gets a "fat" blue spark, definitely stronger than before. The motor will now start, and run for anywhere between a few seconds and a few minutes, before sputtering out. Sometimes upon trying to restart, it will backfire. If i try to give it more throttle, it quickly dies. I havent checked the needle valve yet, and the coils were definitely cracked, not sure where to go next. Don't want to throw any unnecessary money at this right now, just want it to run smoothly in a barrel for now. Should I look into the carb adjustments? Or does this seem like a coil problem?
  #5
Old September 14th, 2006, 12:32 PM
Replacing the coils was the ticket to fixing the starting problems, runs without stalling now! I also put in a carb kit, as the original packing had basically turned to dust. Now for some fine tuning. Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 115 not starting bowrider Johnson & Evinrude Outboards 43 March 28th, 2007 11:01 PM
200 Evinrude not starting ralpht44 Johnson & Evinrude Outboards 2 August 17th, 2006 03:30 PM
59 evinrude 10 hp not starting swimmin' for shore Johnson & Evinrude Outboards 9 August 3rd, 2005 01:34 PM
Starting 3hp Evinrude ke4dc Johnson & Evinrude Outboards 7 February 10th, 2004 01:15 AM
starting 9.5 evinrude M.A.Rotter Johnson & Evinrude Outboards 5 November 30th, 2001 02:21 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
