  #1
Old September 8th, 2006, 11:10 PM
sledstew sledstew is offline
Default 2000 HPDI 150 yamaha warning buzzer going off
I replaced the water impeller last week and that did not fix the problem. When the boat idles at lower rpm eventually the warning buzzer goes off, to get the buzzer to go off I have to drive the boat then it quits. I was wondering what it could be ,I'm leaning toward a bad thermostat on one of the powerheads,but why would it go off at low RPM and clear when you drive it at higher RPM. The owner of the boat said that the pressure gauge on the dash has failed (high) but that happened a couple years ago and it did not affect the warning buzzer.Also is there a pressure sensor for the cooling system on this motor? Any help is appreciated.:|
  #2
Old September 9th, 2006, 07:08 AM
rodbolt rodbolt is offline
Default Re: 2000 HPDI 150 yamaha warning buzzer going off
well a bit of maint as per the service schedule and this problem wont happen usually,
your symptoms indicate a failed pressure control valve grommet.
on the HPDI its a pain to clean and inspect the valve so 90% of the shops and techs simply skip it till it fails.
no water pressure sensor on that motor.
your symptom indicates a lack of wateer pressure in the block and normally it wont keep the stbd bank cool enough.
if your mechanically inclined its an easy service, if not DO NOT attempt it, if you breal the clip on the injector driver you get to spend 1100 on a new driver.
to access the pressure valve requires removing the injector driver,ECU and ECU holder.
  #3
Old September 9th, 2006, 09:16 AM
I own a repair shop for small engines,so I'm thinking I could tackle this,what should I watch for.
  #4
Old September 9th, 2006, 09:19 AM
dont snap off the tabs on the injector driver when dissconecting it. its difficult to describe its uncliping procedure.
but if you dont pull it straight you can shear off the locking tabs.
  #5
Old September 9th, 2006, 09:24 AM
[whisper uid=32169]
Enter private whisper here
[/whisper]
I was wondering if you had the part number for the grommet you are talking about,my model # is VZ150TLRY
2000 HPDI 150
  #6
Old September 9th, 2006, 10:47 AM
not here but if you hit the yamaha website you can find it, its on the exhaust housing. its under cyl crankcase. you will need the gasket possibly and the grommet.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha Warning Buzzer -- Overheating? dharris02 Yamaha & Suzuki Outboards 9 November 4th, 2008 07:45 PM
Warning Buzzer 1988 115 Yamaha SliderM72 Yamaha & Suzuki Outboards 3 August 2nd, 2007 08:04 PM
Yamaha Warning Buzzer seamanship Non-Repair Outboard Discussions 7 September 6th, 2005 02:00 PM
1991 Yamaha 200 warning buzzer martevans Yamaha & Suzuki Outboards 5 July 26th, 2004 07:10 PM
85 Yamaha 90 HP Warning Buzzer ? Help !? starcraft Yamaha & Suzuki Outboards 4 May 19th, 2002 05:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
