starts, won't start, starts, won't start. help
speedy_100
I have a 1991 Wellcraft, 3L Merc. I turn the key, cranks and starts no problems, runs great. Turn off the engine, Starts runs great. After being on the lake and cranking it maybe 7 times (throughout the day), it WILL NOT start.
Ignition fuse is fine. I have power to everything (pump, horn, guages, radio, etc... ). It is in neutral, it's not overheated.
The first time this happened, I waited a while, (angry), then it started up and I got the boat in.
Today, not so lucky.. (angrier)
Don't know what the problem is. Can anyone suggest anything? Thanks.
vipzach
Re: starts, won't start, starts, won't start. help
Welcome to iboats speedy!
Does the motor turn over when it happens or does absolutely nothing happen?
bijou22
I have a Wellcraft 21SL 1997 4.3GL and have always found a problem with the gear shift/throttle control in that in occasionally sticks in gear. Next time it wont start, try turning the prop by hand just to check if it is in gear. I find that a sharp movement of the lever gets me unstuck everytime.
DangerDan
Sounds like a solonoid. Try jumping it (IN NUETRAL) next time you have the problem. That will tell you for sure. Or just replace it. It's realatively inexpensive.
Don S
Ahhhh yes, the old, "Throw parts at it till it's fixed" method of boat repair. Ya forgot to tell him which of the 2 solenoids you are talking about replacing. But it would sure be a waste of money to change solenoides, neutral safety switches and then buy a new ignition switch just to find out you had a loose wire somewhere that could be fixed for free.
Many times I have found loose connections on NEWLY install swithces.
