120 hp vs 140 hp
Status
Not open for further replies.
gbrakner
would any one know what the difference between the 120 hp and 140 hp. I have recently put a rebuild long block into my boat. it was the 140 two peice rear main seal block. how would i know that i got the 140 hp long block vs the 120 hp version?
Re: 120 hp vs 140 hp
The 140hp motor has a Harmonic Balancer mounted to the Crankshaft.........
A 120hp has Only a Pulley on the end of the Crankshaft.......
gbrakner
is the crank or cam different from the 120hp vs the 140?
I Just Told you the Crankshaft IS different.............
Instead of beating around the bush,.............
What Exactly are you Trying to Do,..??....
sankanother1
Nice.....I didnt see that..I read pulley and damper.
Status
