Re: Common problems/failures among older two strokes
I would believe only if it sees use or if water is left sitting in the engine (especially salt water) for a prolonged amount of time will you need to Periodically change it. What type of material is it made of? plastic, stainless steel or something else... if it is not used, none of the elements besides heat and cold from the weather can degrade it. If it is used then the acidic water, debris, salt, and general stresses of use can slowly damage it. so i would think!
