Re: Pull starting a '69 55HP Evinrude
Under some circumstances, such as a bad starter, you can rope start it. But your motor does not have a magneto. It needs a battery with at least enough juice to work the ignition. Once you got it running, the alternator should have been able to keep it running.....maybe. It depends on how dead the battery was and why. Check your alternator/charging, the rectifier may not have survived what it just went through.
