Hey guys, here we go again. Last time i fixed this prob. by adjusting air/fuel mix screws on carbs. It ran pissa! (1985 80 h.p. 4 cyl.)Now , I seem to be back at square 1.
It will rev. up ok in nuetral, in the water tho I do this manually via the carb. linkage. If I rev it w/remote it doesnt acheive same rpms and sounds ruff. Cant get her to idle either without maximizing idle adj. bolt, but when I do this ,I cant shift into gear.After backing off on idle adj. bolt, she will idle, but not correctly, and when i do put it in gear to throttle up test , she stalls. I checked fuel lines to pump & no probs. there.Also getting plenty of spark on all 4.Took fuel pump cover off to inspect diaphram , its pristine.Fuel tank has been used often with new gas(10% ethanol) prior to all of this.Had carbs off during my last issue a month or so ago....they were clean as a whistle....Im about ready to have a bon-fire!!!....any suggestions?
Pete
Pete
