Thanks again for your advice. (cv85 fuel problems). When I took the top plate off the carb the large centre opening had only a rubber disk in it, the large opening to the right had a rubber disk and a metal disk. When I reassmble the carb I used the attached diagram which is opposite from what was existing. When I install the top plate it sits proud in the centre. Is it suppose to sit proud or flat. Is the diagram correct?
