Re: '88 Suzuki 150hp overheating
Warning light did come on on one side which prompted me to check with a laser gun and when it showed about 175/180 degrees plus an extremely hot pee stream I turned off. Other head was holding at about 115/120, therefore no warning lght.
At first I thought maybe I didn't line up the water tube correctly when I put lower unit back on but assume I would have overheat on both heads, not just one? Do you agree? After I did the new impellar and restarted at idle the pee stream was coming but not with a lot of force, then about a minute later it started coming with a lot of force for about 30 seconds, then reverted back to
the lesser (but steady) flow. Sounds like first, before the caustic solution, a back flush would be in order and if so should I flush through the thermostat hole or somewhere else and would it be necessary to drop the lower unit again?
I agree 100% with your feelings about the problems I would have in removing the power head. I only found one post about using a caustic solution and that guy used a hull cleaner. Maybe somebody will have some specific thoughts on what I should use and again where is the best place to put it in? Again, would the open thermostat hole be the best place or do I need to pull something else to gain better acess? Also do you think I need to pull the other thermostat in order to do the other head, or leave well enough alone? Also since I probably will have to give it 2 or 3 doses and will want to run freshwater through in between, assume I can run engine for short time without thermostat housing?
I just recently aquired this engine where all six are showing 90 PSI compression so I really don't know its' history but outwardly (with cowel removed) the engine
looks very clean. Any thoughts on how to flush when boat stays in salt water when there is no fixture on the engine for that purpose? Make any sense to *** it up each time, attach muffs and run, and if so would it be ok to do at full tilt or would it have to be lowered back into the salt water?
thanks again.
