  #1
Old September 5th, 2006, 04:12 PM
stu g stu g is offline
Default 1967 Chris Craft 283 flv asleep for past 13 yrs.
I have been given a 23' Corsair with a 283 flv motor. It's been in storage since 1993. I went out and bought a new battery just to see if it would turn over. It did, but that's about all it does. Where do I start? I pulled the carb and ordered a rebuild kit but I think I'll have issues with spark,etc. Any direction would be great. Also, it seems like the motor turns over slow. I'm not sure if it should turn like a car does or if this is normal for in I/O.
  #2
Old September 10th, 2006, 11:56 PM
seven up's Avatar
seven up seven up is offline
Send a message via ICQ to seven up
Default Re: 1967 Chris Craft 283 flv asleep for past 13 yrs.
what's up stu g,
enjoy !
  #3
Old October 14th, 2006, 06:12 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
pull the distributer, pour oil into hole and use a oil pump priming tool to prime oil pump, and distribut oil thru the engine, it should turn over easier. be sure ti get dist. back in the way it came out.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old December 11th, 2006, 01:50 PM
dogsharks dogsharks is offline
I recently acquired a similar motor, this one being a 327F that had been sitting for SIX YEARS. I first squirted in some PB Blaster (penetrating oil) into the cylinders and let it sit for two weeks. I then squirted in some ATF (Automatic Transmission FLuid has a great lubrication value and it penetrates well too). I used a large screwdriver on this model, to turn the flywheel at the flywheel gear visible through the timing hole. Once the motor was free, I spun it on the starter before connecting it to fuel and fire.
Prior to spinning, I removed the valve covers, and poured lots of oil everywhere, and as much down the lifter pushrod holes as possible, because that goes directly to the cam.
It fired up and ran great. Here it is running with a hose hooked up to it (link to a 15 second video, turn up your speakers)
http://www.network54.com/Forum/42484...ge/1164395538/
This motor is presently being checked for everything. The block had steel freeze plugs, and these have rusted through. Marine engines use brass freeze plugs, so I suspect the block had been changed out years ago for an automotive version. The difference between an automotive 327 and the marine CC version would be 8.0:1 compression on the marine version, and 8.5:1 on the automotive version.
Regards, Dogsharks
  #5
Old October 7th, 2009, 12:48 PM
ChrisCraftLvr ChrisCraftLvr is offline
Just got my first CC Lancer last weekend - its the 19ft with the 307Q. It has been sitting for most of 20 years, and the engine is full of oil and water. I am wondering what effect this has on the bearings - I suspect that the water is fresh, not salt. I'm also planning on yanking the engine out and rebuilding it no matter what. I've had motors full of water before and flushed 'em out with oil/diesel mix, but never had one that had been sitting longer than a few weeks. The dipstick shows that neat milkshake combination all the way up to the top. If its been sitting that way for years now, wouldnt the oil and water tend to seperate back? I'm wondering if someone recently tried to start this thing up and screwed up with the garden hose.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
chris craft constellation chriscraft2005 Boat Topics and Questions (not engine topics) 2 September 22nd, 2005 08:06 AM
Chris Craft Charging Martin Leaney Electrics, Electronics and Trolling Motors 3 May 19th, 2005 11:09 AM
Chris Craft Billnicole Boat Topics and Questions (not engine topics) 1 August 3rd, 2003 01:24 PM
5.7 OMC Chris Craft wvn4k Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 17th, 2003 12:05 PM
81 Chris Craft 253 Martin Leaney Boat Topics and Questions (not engine topics) 5 January 27th, 2003 12:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
