  #1
Old September 4th, 2006, 09:33 PM
onurneez onurneez is offline
Default 72 80hp mercury switch box?
Iv looked up a new switch box and it is not the same one i have the new one has 4 screws on one side and 3 on the other my switch box has only 4 on one side. Plus i used the numbers on the bottom of my switch box and come up with nothing. My motor serial is 3189038 this is the box i find everywhere http://www.foreandaftmarine.com/18-5779.htm
And is this the only thing that could cause me to have no power to coil cause i test power in and i have power but coming out the green i think the one to the coil there is nothing?
  #2
Old September 5th, 2006, 01:23 AM
ricksrster's Avatar
ricksrster ricksrster is offline
Default Re: 72 80hp mercury switch box?
check with Mercury and see if this will work.
http://www.mercurypartsexpress.com/P...85072227062269
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #3
Old September 5th, 2006, 01:43 AM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
Found these part numbers, as you probably did already:
Note that they only fit:
(Serial #s 2783253 thru 2991033, 3052381 thru 3059820, and 3373747 thru 3493912)
Mercury p/n 33-22986A27
CDI Rapair p/n CDI-1142986
Sierra p/n SIE-185779
If you only have 4 connections on one side, where do the 3 wires coming from your distributer housing currently go?
I did find this note on another site, as well:
Serial #s 3051041 thru 3052380 and 3144219 thru 3192962 were equipped with a unique ignition system for which the coil, trigger, and switchbox are discontinued. There is a conversion kit for these models that includes the more common 393-3736A79 trigger and a new switchbox and coil package. Kit # 393-3736A80
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
  #4
Old September 5th, 2006, 09:14 AM
Laddies Laddies is offline
You have a ignition system that was used in 1970 to 71 (serial no 3051041 to 31922962) Mercury had a kit out to replace the whole sysem for a while but it's NLA now the merc no is 337- 4411 abd may be NLA the Rapair no is R337-4411 all they offer is to rebuild your unit. My advice would be to try to find a doner engine and strip the parts off that you need to repace the whole system
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #5
Old September 5th, 2006, 09:41 AM
Chris1956 Chris1956 is offline
Laddies, Did that motor have an unusual ignition system. My '73 850 Merc had the conventional Distributor-based ignition. What kind was on that '72 80HP??
  #6
Old September 5th, 2006, 11:09 AM
Chris your engine should have had the standard battery powered CD with a 393- 3736A- dist and a 332-2986A- switchbox on it, onurneez used a differant dist and switchbox. Your system use a voltage flux caused by a disc with hole turning by a senser to generate a signal to fire the box the other system was a a early try at alternator CD I belive and a winding generated the signal to tigger the system
__________________
  #7
Chris your engine should have had the standard battery powered CD with a 393- 3736A- dist and a 332-2986A- switchbox on it, onurneez used a differant dist and switchbox. Your system use a voltage flux caused by a disc with hole turning by a senser to generate a signal to fire the box the other system was a a early try at alternator CD I belive and a winding generated the signal to trigger the system
__________________
  #8
Old September 5th, 2006, 02:59 PM
Laddies, I had no idea that Merc had that varient. Since they went "back" to the distributor-based system I will guess it was not too successful.
  #9
Old September 5th, 2006, 10:50 PM
i called a place in alabama today that makes the ignition parts and told him the part number i had on my box and this is what he gave me 114-2986K1 and said this is a kit which comes with box, trigger, and coil. $600 and still not for sure this will solve my problem.
  #10
Old September 6th, 2006, 09:30 AM
Onurneez,
Thats the Rapair part number for the kit, I have never installed one of there kits but they are the best marine electronics firm around so as long as the cap and rotor are good it should fix your problem.
Chris,
Since last night I got out a manual to ck on the old system out and find that I was wrong about the system being a early try at alternator driven CD, that would have been the Lightning Energizer system used on the 1970 to 75 50HP engines. The system for the 800s was a variation of battery powered CD--Bob
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
replacing ignition switch on 79 merc 80hp ayenlit Mercury & Mariner Outboards 3 August 2nd, 2005 08:00 AM
What year and oil mix is my mercury 80HP bottomofsea Mercury & Mariner Outboards 6 June 28th, 2004 04:25 PM
84 mercury 80hp new owner wolfman69181 Mercury & Mariner Outboards 1 June 7th, 2003 08:46 PM
Mercury, 800 80HP 197? muttmike Mercury & Mariner Outboards 0 April 30th, 2003 10:19 AM
79 Mercury 80HP earthraper Mercury & Mariner Outboards 2 February 17th, 2002 10:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
