  #1
Old September 4th, 2006, 09:11 PM
johnny whaler johnny whaler is offline
Default 1978 Evinrude 35 hp long shaft won't run right
I have a 78 Evinrude 35hp on a 1963 13' whaler. I took it out last week after I bought it and had it running and it ran great after I played with it in the driveway for a while. Once out on the water it ran great but tended to cough and spit on idle and it wasn't real smooth. It hadn't been run in a long time. It wasn't pumping real great and the local boat yard mechanic said they are famous for a stuck thermostat. He pulled it out and repalced the head gasket too at the same time. Once again it ran great in the driveway but I got it out and it ran ok but then started up again coughing and sputtering and then fouled the plugs. I put in a new set and it ran ok for about 15 minutes and fouled them too. Did the same with a 3rd set.
The only setting I see it the low sped setting and I was told to start at 3 turns. It runs turned down to one turn and all the way up at 3 turns. It really is strange. It runs like new with new plugs then go to heck in 10-15 minutes.
I ran QL77JC4 plugs and L78V plugs and it did the same with both. I am thinking it's a carb problem. I did notice that the last time when I opened the engine cover there was some fuel that came out of the front of the carb along the airbox.
Any suggestions as to where to start is appreciated. I bought it knowing there were issues. The previous owner was told by the big boat dealer in Norwalk that it had a bad crank seal but the thing has 140PSI in each cyl which I though it would never have with a defective crank seal. Not sure how to tell if this is the problem or if they just didn't want to work on a 1978 outboard. Any idea what the symtoms of a bad crank seal are?
It's too good to throw away...help if you can...Thanks!
  #2
Old September 4th, 2006, 09:23 PM
KYHunter2 KYHunter2 is offline
Default Re: 1978 Evinrude 35 hp long shaft won't run right
Since it sat for awhile .
Rebuild carbs, water pump , and thermostats.
Its a bad idea to run it without the thermostats.
Running the motor too cool, is just as bad as too hot.
Take a look at awakening a sleeping outboard , in the FAQ's.
Also a decarb is in order.
KYHunter
  #3
Old September 4th, 2006, 09:55 PM
F_R F_R is online now
Throw those L78Vs away. If the lower crank seal is bad, it's difficult to tell without pulling the powerhead.
A bad crank seal won't show up in a compression test. Try a cylinder balance test by shorting out the spark plugs (at fast idle) one at a time and see if RPM changes more with one than the other. The one with least change is the weak one and the seal could be the cause.
Coughing at slow speed indicates a lean condition, or a too cool condition. A bad crank seal admits air, also causing a lean condition on that cylinder. Try turning the needle to the left a bit. Or it could be a carb problem.
What appears to be fouled plugs aren't necessarily really fouled. They can look like crap and still be OK.
  #4
Old September 5th, 2006, 08:48 AM
fireman57 fireman57 is offline
If you are spitting fuel out the front of the carb take it off and look into the reed valves for something in there. My boat was running great on Saturday when all of a sudden it felt like I dropped a cylinder. Took off the airbox and carb because I thought I might have had a stuck float but looked into the reeds and one of the bolts from the airbox had come loose and it was back there. Ten minutes later we were cruising again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 70Hp Evinrude Lower Unit Long Shaft or Short Shaft HBF4 Johnson & Evinrude Outboards 3 April 23rd, 2006 07:10 AM
converting evinrude 1984 9.9 long shaft to short shaft alan5505 Johnson & Evinrude Outboards 8 February 28th, 2006 04:58 AM
1971 Evinrude long shaft to short shaft alderman Johnson & Evinrude Outboards 3 September 14th, 2004 03:22 AM
25 HP Evinrude long shaft conversion to short shaft P. S. Johnson & Evinrude Outboards 1 June 3rd, 2003 10:15 AM
Evinrude Short Shaft to Long Shaft Question. thebigbuck Johnson & Evinrude Outboards 8 March 12th, 2003 11:59 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
