I have a 3 HP Evinrude folder, I am modifing a custom Herreshoff out board bracket for a 1917 Herreshoff sail boat, that allowed You to attach and outboard to the transom, it was made for a long shaft OB so I am lowering the mount to get the 3 HP lower in the water. Just how far down should the shaft of the moter go into the water, with out the modification is just barely covers the prop when on the boat. In relation to the anti cavitaton plate and the coupler that lets You fold the shaft , between those 2 points were should the water level be ?
Thanks
Thanks
