  #1
Old September 3rd, 2006, 05:16 PM
rand5g rand5g is offline
Default Buying Mercury 150, 2000 from dealer need help?
I am buying a Trophy boat froma dealer with a mercury 15 hp 2 storke dated 2000. They have agreed to go over the motor for me before purchase and fix or replace anything that needs it. The boat is a year 2000 and they are claiming under 5o hours total use. Is there specific things I should have them replace like water pump, spark plugs, lower end unit oil etc that are out of date even though it has low hours. What should I be having them specificaly due. I am treating it like a wish list. Any thought would help, thanks Rand
  #2
Old September 3rd, 2006, 05:36 PM
andy6374 andy6374 is offline
Default Re: Buying Mercury 150, 2000 from dealer need help?
Definitely have them put a new waterpump in. I would also change out the tstat if has one.
If it is running the least bit rough I tell them to rebuild the carbs and fuel pump.
  #3
Old September 3rd, 2006, 11:08 PM
Thanks, for quick reply, Rand
  #4
Old September 3rd, 2006, 11:24 PM
Plainsman's Avatar
Plainsman Plainsman is offline
I think you named off the imortant things. Have them do a compression test as well.
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
  #5
Old September 3rd, 2006, 11:41 PM
ncfish1 ncfish1 is offline
The 2000 Trophy with 150 Merc. is a good combination as I own one. It's important that you have the head gaskets, t'stats, impeller and poppet assembly replaced. After these repairs, run the boat and check the speedometer and gas gauge; both give problems. I would also have a temperature gauge installed; you'll be glad you did. Check the oil tank bracket for corrosion; have them replace it if corrosion is visable otherwise, you will replace it later (not very sturdy).
If the trophy is a center console, have water put in the 2 fish boxes at the transom port and starboard floor. Make sure the water drains properly into the center bilge tank. If not, have them correct the drains (factory installed up-hill drains-not to efficient). The boat and motor are excellent other than the mentioned points and runs well offshore or inshore and is excellent on fuel.
  #6
Old September 4th, 2006, 03:27 PM
thanks again, all very helpful, keep it coming if you got it> Rand
  #7
Old September 4th, 2006, 03:30 PM
PS, what would a bad result of a compression test read? Rand
  #8
Old September 4th, 2006, 03:34 PM
it is a walk around....if that helps...Rand
  #9
Old September 4th, 2006, 05:11 PM
With the cylinder block warm, battery fully charged & throttle shutters wide open, you should have between 110-135 psi (733.3-924.5 kPa). Variance between cylinders should not exceed 15 psi (102.7 kPa)
  #10
Old September 4th, 2006, 09:10 PM
Should the tech be able to give me the results for compression or is that asking too much?
  #11
Old September 4th, 2006, 10:01 PM
Absolutely! I would ask for the results of each cylinder test and then compare the results with what you know it should be. If you see that you are within the acceptable tolerances, then you should be safe with the motor operation (at least with the compression question).
  #12
Old September 5th, 2006, 09:19 PM
Thanks for all the help!!!! I will post what comes up, thanks Rand
  #13
Old September 6th, 2006, 05:00 AM
cougar1985's Avatar
cougar1985 cougar1985 is offline
tech can give you any results he wants.it is best to be on hand to see the results of the compression test yourself.this will eliminate a shaddy deal,and a reputable dealer shouldnt mind atall.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Buying a 2000 200XL Optimax vs. 1997 200XL timo14 Mercury & Mariner Outboards 3 August 11th, 2005 08:06 AM
Buying -79 Mercury 80 hp, need info. Bjornis Mercury & Mariner Outboards 4 August 26th, 2004 01:15 PM
fuel pump for mercury 200hp efi??? is dealer ripping me off dj_kev Mercury & Mariner Outboards 6 September 29th, 2003 05:19 PM
Head Gasket at a Mercury Dealer? turtle1173 Force & Chrysler Outboards 2 August 14th, 2003 04:20 PM
Mercury 25 HP overheated after dealer service dlittle Mercury & Mariner Outboards 1 May 10th, 2002 04:45 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
