  #1
Old September 3rd, 2006, 05:06 PM
imported_Andy_P imported_Andy_P is offline
Default 1986 Mercury 60HP Burnt Piston - What Caused it?
I bought this engine in pieces and cheap due to it "needing a piston". Visual inspection shows a very clean engine, two other normal-looking pistons, and undamaged cylinders. Just the top (#1?) piston is damaged as shown.
Just wondering what might have caused it. Don't want to repair it, only to have it happen again. The previous owner spoke of "last-year's gas/oil mix as having gone bad".
  #2
Old September 3rd, 2006, 06:33 PM
xmen3 xmen3 is offline
Default Re: 1986 Mercury 60HP Burnt Piston - What Caused it?
2 things it could be or a combination of both.
Overheating or detonation.
Possible for a motor with a good impellor to get air trapped in the block on certain models cooking #1 while still having a good telltail.
Also blockage in the carb will cause it to run lean.
Looks like your piston is damaged from the center out suggesting the plug is running too hot or detonating.Start by checking impellor and cleaning carbs and setting timing.
  #3
Old September 3rd, 2006, 06:42 PM
emckelvy emckelvy is offline
Overheating; bad gas; too much timing; overloading the engine by propping it too "tall" for it to achieve maximum recommended W.O.T. rpm.
Any one of these or combination thereof could have caused that type of damage.
These 'small-bore' 3-cyl's are very overstressed and don't handle large loads or lugging the motor very well.
Check the top cylinder very carefully for cracks. You'll want to remove the water jacket cover over the spark plugs to inspect the outer side of the combustion chamber's dome for damage.
I've seen quite a few of the old 650 and 700 Triples crack #1 cyl when they lose an impeller and overheat underway. The 60 is just a 'prop rated' version of these motors.
From what I understand there is also supposed to be a mod performed to the blocks, to relieve a potential 'steam pocket' at the top of the block which can crack #1 cyl. The water telltale hose should be located at the top, which will vent the block and ensure it's completely flooded with water. If the fitting is not already there, you can <very carefully> determine the right spot to drill the block and tap for a 1/8"-NPT fitting for the telltale hose. Then plug up the original location of the telltale fitting.
Make sure the water pump and impeller are A-1.
When you get 'er back together, set the timing for no more than 21 deg BTDC. Use midgrade or premium, non-alcohol fuel if possible. Use a quality TCW-3 oil. Prop the motor to be at the top of its rpm band at Wide Open Throttle, with a lightly-loaded boat. Probably not a bad idea to replace the impeller yearly, too.
That should help keep it from going thermonuclear again!
HTH & G'luck............ed
  #4
Old September 4th, 2006, 10:29 AM
Texasmark's Avatar
Texasmark Texasmark is offline
Is this the way it came from the engine? You didn't clean off any carbon or oily residue off the crown?
Mark
  #5
Old September 4th, 2006, 04:23 PM
Quote:
Mark
I think so, but can't say for sure as I didn't do the disassembly.
  #6
Old September 4th, 2006, 10:50 PM
Texasmark's Avatar
Well it's dry; like it was run way lean. Never saw detonation that bad. You should have heard it pinging having done that much damage.
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
merc 650 - melted top piston rings! what could have caused this? casi77 Mercury & Mariner Outboards 7 December 11th, 2006 03:20 PM
burnt piston bicskies Johnson & Evinrude Outboards 1 June 18th, 2006 08:52 AM
Burnt piston Fishenjim Johnson & Evinrude Outboards 3 January 9th, 2004 12:10 PM
What caused piston to burn? hookedonjc Johnson & Evinrude Outboards 21 January 9th, 2004 02:47 AM
Burnt piston and burnt cylinder wall, How should I repair? sandman Johnson & Evinrude Outboards 4 March 12th, 2002 04:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
