yosuthnmasa
- Jul 27, 2006
- 8
First off, what a great site! There is a ton of information to be had here and some very nice people.
I recently bought a 51-53 model 5hp Goodyear outboard motor. I've got a few questions about it.
On the serial number sticker it says the oil to gas ratio is 1/2 pint oil per gallon gas. Is this equivalent to a 16:1 mixture?
I read on some older threads that this motor was made by Gale a division of OCW and that it should be almost identical to an equivalent Johnson/Evinrude of the same year. Is this correct?
I would also like to get a service manual and parts catalog. I checked out kencook.com and the price of those two items will almost cost me more than what I paid for the motor. Is there any other options for getting manuals without having to pay such a hefty price?
I mounted this motor on a small aluminum boat. It doesn't seem to be opening up very much when I throttle it up. If this motor isn't almost perfectly parallel with the boat it doesn't want to start or run. When it gets low on gas, it revs up really high( the rpms or higher than when I have it full throttle with a full tank) and then calms down. It does this over and over until it kills. The spark plugs seem to be a bit wet and maybe fouled. Does it sound like I have a carburetor problem, maybe float problem?
Thanks for the help!
