Re: EVINRUDE AGE AND MODILE BY SERIAL##
Where hae you looked for the numbers??
The model number should be:
1)On a rectangular tag somewhere on the transom clasp (where the motor connects to boat)
2)There should be a round metal plug on the engine block that will have the model/serial numbers.
If you motor is old enough the model number will be all numbers and look like a serial number. Post what you have found so we can help you.
Welcome to iboats8)
