Re: Four Barrel Miss
I'm confused by your last post, too. If it's always been there, and it is in fact a Holley, you might want to order a trick or tuner kit for it. They come with multiple jet sizes, diaphragm springs, etc. and are designed to help you set the carb up to your specific application. Might be some screwing around, but might solve the problem, too. Check out this website:
http://www.bob2000.com/carb.htm
Found this on there:
"Question: Is the Holley spreadbore better than my Rochester Quadrajet?
Answer: Not at all. The Holley spreadbore carb is a poor imitation of the Rochester Quadrajet. Here's why.
The Rochester Quadrajet is a modern design, and uses some very forward-thinking features such as a central float bowl with one float, vacuum-operated metering rods for power enrichment, an air-door controlled secondary, and no gaskets below fuel level. A couple of disadvantages are its sliding cup accelerator pump, and hard-to-find parts.
So, how does this relate to Holleys, since this is a Holley page? The design of the Holley spreadbore replacement leaves out many of the good features Holleys are famous for, and leaves off most of the good features of Rochester Quadrajets.
The Holley spreadbore lacks these features, which are standard on its squarebores: Externally adjustable floats, standard accelerator pump nozzles, standard gaskets.
The Holley lacks these features, standard on a Rochester Quadrajet: Metering rods for power enrichment, air-door controlled secondary.
Since the Holley is lacking in so many things that the Quadrajet excels at, I recommend to anyone who is thinking of putting a Holley spreadbore on any engine: Don't! If you have a spreadbore intake, use a Rochester Quadrajet. If you really want a Holley, change the intake manifold to use a squarebore Holley. Don't use adapters, either! They are proven power robbers. "
