Would someone be able to give some guidance re: adjusting the idle? Motor will start with shift lever forward in the "start" mode but when shift is pulled back to neutral, the engine sputters and dies. I believe I need to set the idle higher, but don't know where the adjustment screws are or which way to turn them or by how much..thanks
