SgtScrounge
- Jul 25, 2006
- 25
'93 225 hp Evinrude Ocean. Bought boat 3 weeks ago, moved it 25 miles to a temporary slip. The motor shut down 800 yds from the slip. Next day, I replaced the water sep and in-line filter. Took it out again, ran fine then RPM's went down and it shut off. 2 hours later, it starts up fine and runs great again.It has done this 3 times, same basic pattern. Dash temp gauge never went over 170 degrees. Water jet is strong.
The motor is set up as pre-mix w/ oil line to VRO plugged. Wiring to VRO is unplugged. There is no alarm.
Why is it shutting down, and what do I do to fix it ?
