Re: FUEL HOSE CLAMPS?
on the low pressure pumps, cut the tie straps and carefuly push the lines off the pump nipples, remove the 10mm hex fasteners and try to shear the pump away from the gasket. if the gasket does not tear it reusable. if the VST oring does not swell it reusable. if need be use vasoline to retain it in the groove.
