Johnson TJ115LETS Is it damaged????
MOETOROLA1
I noticed on two of the four reed cages that there is a small ding or dent on the reed cage itself. Right on the curve of the opening. It appears to be from the manfacturing process, because the reeds are perfect themselves. the indention is about the size of the brass end of a bic pen.maybe a bit smaller. but you can see thru it when held up to the light. The engine seems to run good 5000rpm with a 14x19 @ 48mph nitro 17'.
The dent is on 1 of the 8 openings in the reed cage and on 2 seprate rees cages. Hope i didnt confuse anyone.
Thanks Brian
