Re: Coil info
Car parts are not all the same as boat parts. I'm not sure why a coil would be different, but a starter is different and so are all relays. A boat with the plug in the back can collect fumes from the gas tank, while a car engine compartment will not. If these fumes find a spark then BOOM. The marine starters, marine relays, and marine battery chargers will not throw a spark and cause ignition. Now generally there shouldn't be fumes in the boat anyway - but better safe then BOOM.
I have seen this myself when the floats on my merc were stuck and gas dripped out of the front of the carb - and right onto the starter relay. I kept cranking the engine and did not have any fire.
Go to the MSD or Accel web sites and see if they make a marine coil...
- Brian
