Help finding part number for Mercruiser trim hose
cheburashka
I'm replacing both of the inside hydraulic lines on my Pre-Alpha outdrive. I found the first one which connects the pump to the junction block. It's listed as an 18-2107 in Sierra and it's 21" long. I'm having trouble finding the second one, which returns from the junction block to a fitting on the transom (reverse lock valve?) and is 24" long. Both have the same connectors: 1/4" fittings, 90 degrees on one side and 45 degrees on the other. Does anyone have a source for this hydraulic line? Does Sierra make it, or do I have to go OEM?
Thanks
cheburashka
Re: Help finding part number for Mercruiser trim hose
That helped. Parts ordered and on their way.
It's amazing what twenty-two years in a wet environment does to rubber products.
It's also amazing that someone would replace a bad pump motor and re-use twenty-year-old hoses.
