Hard Starting when engine is cold
markwarren
Hi - I have a 4.3 Merc, 2002. It has turn-key starting, which is used to do quite well.
I've had the boat about 6 weeks. The first weekend I took it out, the battery was dead so I replaced it. The boat started up just fine the first 2-3 times on the water, with about 1 week in between outings.
Recently, it has become increasingly difficult to start. The engine cranks, but it started taking 5-10 seconds to run. Yesterday, it took 3-4 10-second attempts before it started, and then it died. Started again right away and it ran fine. The boat had been sitting for 2 weeks prior to be used yesterday.
It always starts immediately when the engine is warm.
Are there any obvious things I should look for prior to taking to the shop?
I'm most concerned that the situation appears to be getting progessively worse.
Thanks
Alumarine
Re: Hard Starting when engine is cold
Is this a carb engine or fuel infected?
markwarren
Specs state that it is a "2V Carb with Turn Key Start & Electric Fuel Pump"
I don't have a choke or primer bulb - supposed to just turn the key and it starts.
Alumarine
Sorry, don't know anything about turn key start.
Thought it might have had a choke.
Here's a bump though.
