  #1
Old August 26th, 2006, 05:14 PM
Red Rover Red Rover is offline
Default 82 evinrude ignition problem (blowing fuse)
The other day I went to start my boat. And the ignition just fell apart, the back fell off. So I got a new one with 6 terminals, S C B M M and I, the only dif. is the old one had an A where the new has an I. So I hooked it up
S - yellow w/ red stripe
C - purple w/ white stripe
B - red w/ purple stripe
M - black w/ yellow stripe
I - purple
M - black
This was matching the old ingition except for the dif. between a and i . So I turn the ignition and click then the fuse blows. Any help would be greatly appreciated.
  #2
Old August 26th, 2006, 05:44 PM
F_R F_R is offline
Default Re: 82 evinrude ignition problem (blowing fuse)
Sounds good. You are going to have to get an ohmeter and check out the switch and/or other wiring. The continuity readings on the switch should be:
Switch off: M to M. only
Switch on: B to I (A) only
Switch to start: B to I and B to S only
Switch to choke: Same as on and start, plus B to C. only
If the switch checks out, you have a short somewhere else.
  #3
Old August 26th, 2006, 05:55 PM
F R, I do have an ohmeter, but what exactly do I need to do to check continuity. Thanks
  #4
Old August 26th, 2006, 08:12 PM
F_R F_R is offline
Disconnect all the wires from the switch. With meter set at some mid-range scale, touch the leads to the specified terminals with key in specified position. Continuity will show as near zero ohms, no-continuity as near infinity.
I forgot to mention, there should NEVER be any continuity between either M terminal and any other terminal except the other M. That includes momentary contact when turning or pushing the key. I have a sneaking suspicion that it might have this fault, which would blow the fuse.
  #5
Old August 27th, 2006, 03:05 PM
ok, so I checked out all the terminals and they all checked out. So I guess it's back to the drawing board, where else would be a problem area for a short?
  #6
Old August 27th, 2006, 04:00 PM
ezeke ezeke is offline
Isolate the short. It is either the choke solenoid [C], the starter solenoid [S] or something connected off the A [i] terminal.
The positive red w/purple is OK or it would blow the fuse before you turned the key.
  #7
Old August 27th, 2006, 04:23 PM
F_R F_R is offline
Considering how tightly those wires are crammed into a small space, I would consider maybe the problem could be right in there someplace. Any wire that may have the insulation mashed would be suspect. Even adjacent wires where they connect to the switch if they lie tightly side-by-side. Another prime suspect would be where the purple wire connects to the hot horn; if it is bent down, the terminal could be contacting the horn body.
There really isn't much to go wrong other than bare wires. The switch feeds the hot horn, choke solenoid, tachometer plug, and starter solenoid. None of those are famous for shorting out in themselves. Resistance tests on each wire are necessary to isolate problems in those areas.
  #8
Old August 27th, 2006, 04:26 PM
F_R F_R is offline
Well, I'd have to think about the comment concerning the horn. Hm-m-m-m
  #9
Old August 27th, 2006, 05:23 PM
so, I changed the C, S, and I wires and the fuse is still blowing. I checked the continuity with the wires attached but the battery disconnected and there was continuity between M and C. Is that normal, or is there not supposed to be continuity between M and C even with the wires own.
  #10
Old August 27th, 2006, 05:45 PM
No continuity between M and C is correct.
M is the kill wire. When closed by turning the switch to OFF, it grounds out the power pack. Nothing else except your emergency cutoff switch should be on that circuit.
  #11
Old August 27th, 2006, 05:56 PM
I'm sorry this is confusing to me, bet when the wires are attached to the ignition, and it is off, I have continuity between M and M, and M and C. If I take the wires off then there is no continuity between M and C, but stiil between the M's.
  #12
Old August 27th, 2006, 06:01 PM
Neither M should have continuity with anything when the switch is in on, start or choke, and only with each other when off.
Disconnect the choke wire from C and see if the problem stops.
  #13
Old August 27th, 2006, 06:46 PM
alright good news, I disconnected C and it worked. So does that mean the choke solenoid is bad?
  #14
Old August 27th, 2006, 06:54 PM
Maybe. Could be the wiring. You could isolate that by reconnecting the C and disconnecting the choke solenoid wire at the motor.
I am a little concerned that you could get power to the power pack and damage it.
Check the choke solenoid wiring carefully at the engine.
  #15
Old August 27th, 2006, 08:37 PM
F_R F_R is offline
You are confusing yourself and everybody else with invalid continuity checks. With the switch off and all wires disconnected, there should be continuity between M and M (not C). With the two M wires connected, they are both connected to ground with the switch off. But here's the rub: The choke wire is also connected to ground via the electro-magnet coil in the solenoid, albeit there would be a few ohms resistance....whatever the coil is. So, to make a long story short, what you are doing is connecting one ohmmeter lead to ground (M), and the other one also to ground through the choke solenoid. Result: a continuity reading. But it's an invalid test.
  #16
Old August 27th, 2006, 08:38 PM
Tom Scully Tom Scully is offline
"I have continuity between M and M, and M and C. If I take the wires off then there is no continuity between M and C, but stiil between the M's."
With the wires on the switch you will see the resistance of the choke coil between C and M because one of the M's is ground. So by reading the switch with the wires on you are essentially checking the choke soleniod and wiring by measuring arcoss M and C.
"alright good news, I disconnected C and it worked. So does that mean the choke solenoid is bad?"
Could be the solenoid or the choke wire is shorted to ground. The terminal on the choke solenoid is mounted in very close quarters, make sure it's not touching the block.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
150 1999 Evinrude blowing 20 amp fuse RAYHYAR Johnson & Evinrude Outboards 5 February 13th, 2007 03:51 PM
Ignition fuse problem bajaman350 Electrics, Electronics and Trolling Motors 2 May 31st, 2006 08:47 PM
help - blowing ignition fuse. free67 Mercury & Mariner Outboards 2 March 16th, 2006 10:27 AM
hot ignition fuse blowing.25hp johnson 1978 lugworm Johnson & Evinrude Outboards 0 September 15th, 2005 07:41 AM
Mercruiser 3.0 blowing ignition fuses/alternator problem ? bowriderbob Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 August 15th, 2005 08:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
