  #1
Old August 25th, 2006, 11:34 PM
gorco gorco is offline
Default Mariner 115hp spark plug type
I need help identifing what's the correct type of spark plug for my 1990 Mariner 115 4cyl.
On one page of the 90-93 Clymer manual I have states the motor takes a standard gap NGK BP8H-10 plug. Another page states it takes a surface gap NGK BU8H plug.
Also, the manual states all other hp models above 5hp take surface gap plugs.
I find it odd that the 100 and 115 take standard gap plugs when most of the rest take surface gap plugs.
Any help or guidance is greatly appreciated.
ps. I am new to this forum and I think it's great.
Thanks
Steve
  #2
Old August 26th, 2006, 01:21 AM
wbblc87 wbblc87 is offline
Default Re: Mariner 115hp spark plug type
Thanks
Steve
It depends on the serial number of your engine whether it takes BUHW or BP8HN-10. Get me your ser# and I can tell ya. Bill
  #3
Old August 27th, 2006, 06:06 PM
Bill,
The serial number is OC227571.
Thanks for helping.
Steve
  #4
Old August 29th, 2006, 08:13 AM
Any thoughts Bill?
Thanks
  #5
Old August 29th, 2006, 11:24 AM
Texasmark's Avatar
Texasmark Texasmark is offline
My last 3 mercs have had surface gap and I am still trying to figure out the advantage over standard plugs; Mid 80's 4 cyl 85, '89 115 6 cyl, and '02 90 hp 3 cyl.
Only thing I can tell is that they run forever. My 115 ran the same set for 7 years with stellar performance.
Mark
  #6
Old August 29th, 2006, 08:35 PM
My 115 runs great too, but I can only get 4100 rpms at WOT. It has a Quicksilver Laser II 20" prop on a 18 foot 900 lbs flats boat.
I suspect the prop is too much for the boat/motor combo, but before I buy a new prop, I want to make sure I have the correct spark plugs in it.
Steve
  #7
Old August 29th, 2006, 09:08 PM
phatmanmike phatmanmike is offline
all the mercs run on surface gap NGKs. dont question it! it works great, JUST DO IT !....... or else.......:devil:
  #8
Old August 29th, 2006, 09:36 PM
Is there any chance I'll damage anything if I switch from standard to surface gap plugs?
  #9
Old August 30th, 2006, 12:14 PM
Chris1956 Chris1956 is offline
Mike and Gorco, Mercury changed the Spark Plug numbers for the newest inline sixes, and certainly for motors that superceeded the classic inline 4s and 6s. It is a simple matter to look on the spark plug web sites, or at a local auto parts place to get the correct plug number for your motor. If I had to guess, Gorco's motor will use the gap-type plug. I recommend that Gorco and Mike run what is recommended for their motors. I also think that surface-gap plugs stink, but I am stuck with them in my inline, unless I am willing to take a risk with someother plug.
  #10
Old August 30th, 2006, 12:17 PM
Texasmark's Avatar
As far as hurting somehing your piston could come up and strike the plugs protruding element, or if the wrong heat range there is a possibility of a burned piston crown.....picked that up from listening to others talk on here.
Mark
  #11
Old August 30th, 2006, 12:22 PM
Texasmark's Avatar
Hey Gorco, You are probably correct. Flats boats have a lot of hull in the water, hence a lot of drag. I ran a 19P HP SS back in '89, was a merc prop but don't remember what the name of it was.
It was the 115 tower and was on a heavy 17' Ranger Fisherman (680) which was padded and I would run 6 grand at WOT consistently. The pad (and trim) did the trick.
Mark
  #12
Old August 30th, 2006, 02:14 PM
I'm going stick with the standard plugs.
Thanks for all the comments.
Steve
  #13
Old August 30th, 2006, 04:39 PM
emckelvy emckelvy is offline
If you go to the www.mercurypartsexpress.com site and plug in your ser #, you can access parts diagrams for your motor.
The "electrical components" parts diagram shows the spark plugs as "Ref # 10".
Click on the yellow highlighted # to get specific footnotes as applicable to each part.
In the case of the spark plugs, it lists #'s for standard, RFI supression, and Canadian/Belguim motors.
It lists the standard plug for your motor as a surface-gap NGK BUHW.
It lists an RFI Supression plug for your motor as standard-gap NGK BP8H-N-10.
If you do a lot of idling, the standard-gap would probably do better. If you do a lot of hi-speed running, the surface gap plugs may run a bit cooler and last longer but overall it's a tossup. If you've gotten good service out of the standard-gapped plugs then there's no reason not to continue to use them.
BTW I've worked on a number of the Big-Bore 3's and 4's, and they've all had standard-gapped plugs.
Here's links to specs on each type of plug:
http://boating.aquamoon.org/product_...g-BP8HN10.html
http://www.boating.aquamoon.org/prod...park-Plug.html
HTH........ed
  #14
Old August 30th, 2006, 06:49 PM
Ed,
Thanks for the info and the link to www.mercurypartsexpress.com. I didn't know about it.
I'll stick with standard plugs for now. My next step is to try different propellers.
Thanks
Steve
  #15
Old August 31st, 2006, 01:12 AM
One thing about these motors, they are not rev-happy as were the older Inline Six Towers of Power.
Best performance will be a prop whose WOT rpm falls within the mfr's recommended rpm range.
Whether you prop to the top or bottom of that range depends on what type of boating you do.
Cheers..........ed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What type of Spark Plug should be used? lajmap1204 Johnson & Evinrude Outboards 5 April 10th, 2006 07:13 AM
spark plug gap & type - 1991 Mariner 9.9 w8in499 Mercury & Mariner Outboards 1 September 5th, 2005 09:25 AM
What type of spark plug? crocket104 Mercury & Mariner Outboards 2 July 30th, 2003 08:09 PM
what type of spark plug???? ripper1 Johnson & Evinrude Outboards 2 July 7th, 2003 02:39 PM
Spark Plug Type and Gap tgleeson Johnson & Evinrude Outboards 0 May 11th, 2003 08:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
