Re: 67 35H.P Evinrude shaft is welded
Most likely you're going to have to replace the gearset in the lower unit at a minimum, or possibly the entire lower unit. That's the part that the propeller attaches to.
Look between the transom clamps, on top of the tilt/swivel steering bracket and see if you can find a model number on the nameplate. Failing that, check the port transom clamp for a nameplate. If you don't find one in either place, check the engine block near the spark plug end for a convex silver plug, about the size of a quarter with numbers stamped into it.
If none of that works out, post a picture here.
