  #1
Old August 24th, 2006, 10:09 AM
onabender onabender is offline
Default What length trailer for a 24' pontoon boat?
I had a boat next to gave to me and I'm going to restore it this fall/winter. It doesn't have a trailer so I'm in the market for one. Which is better a bunk style or a lift? I'll be leaving it on the trailer so I was just going to go with a bunk style. What length of trailer is recommended though? I'm not sure how the trailers are measured in correspondance to the boat length. Are they spec'd by the bunk length or from hitch to tail or what? I'd just hate to look at a trailer that is too short if I find one from an individual.
  #2
Old August 24th, 2006, 11:23 AM
Reel Poor's Avatar
Reel Poor Reel Poor is offline
Default Re: What length trailer for a 24' pontoon boat?
You will need a 22-24 pontoon boat trailer. Should also be a tandem axle trailer.
__________________
Of those who receive good advice, only the wise will profit from it.
If you need it....Get it
If you want it....Wait
If you have it....Flaunt it
  #3
Old August 24th, 2006, 12:09 PM
imported_John o imported_John o is offline
The best site for pontoon boats is Pontoon and Deckboat Magazine's forums at: http://www.pontoon.net/fusetalk/foru....cfm?forumid=3
The type of trailer you want kind of depends on your circumstances. I prefer the bunk style as I feel it gives better structural support to the boat. The lift (or scissors) style supports the boat on the crossmembers and leaves the logs hanging. I just don't feel good about that for trailering the boat any great distance. On the other hand the lift will let you set the boat down on blocks or even directly to the ground while a bunk will not.
(There is a company called Grov'lander (http://www.grovlander.com/index.htm
) which will let you sit your pontoon directly to the ground if need be, kind of a roll-on roll-off sort of arrangement. It's a bunk/roller tilting type trailer)
You will want a trailer built for a 24' pontoon. The ends of the logs should be supported by the ends of the bunks anything else is too short. If the trailer is too long you can also run into trouble on some ramps.
I've got a 24' pontoon that sits on a 24' trailer by Hoosier trailers (http://www.hoosiertrailer.com/). The actual trailer length is closer to 30' or 32'. When I'm up against the stops the bunks are just a couple inches past the logs.
You will definitely want a dual axle trailer and you will want brakes, preferably on both axles. I've got surge brakes on mine and they seem to work great. My trailer tows and stops easily. A pontoon tows heavier than it really is as there is a lot of sail area on that big front fence. Not too much side to side movement on mine but I can feel the wind up front.
Unless you have a cover specifically designed for towing plan on towing the boat uncovered. It's almost impossible to stop air leakage under the covers of pontoon boats. And the wind will shred a standard mooring cover in short order.
Unfortunately I don't have access to PDM forums from here but do a search for trailer types. Also in the general discussion area there is a FAQ topic that has three or four trailer entries. Lots of good info and lots of good people there specializing in pontoons.
I've not checked iboats for pontoon rebuild stuff as I bought a new boat before I found this site but I do know that Pontoon Stuff (http://www.pontoonstuff.com/) has a complete selection of everything you'd ever need to do a rebuild.
__________________
2007 Manitou Osprey Pro SHP
Yamaha 175 HPDI VMAX
  #4
Old August 24th, 2006, 12:11 PM
Onabender,
Just noticed you're in Jasper. I'm up in Bedford. Small world isn't it.
__________________
  #5
Old August 25th, 2006, 05:30 PM
Thanks for the info. The boat was delivered by my father in law from Lake Barkley in Cadiz, KY. He brought it up on a 28ft trailer and the bunks were way longer than the logs. Getting it off was interesting 1) glad I'm an engineer and 2) glad I was on a farm. We raised the back of the boat with a loader and drove the trailer almost all way out, shy 4ft or so adn set it up on blocks. The we lifted the front and pulled the trailer out. Wasn't to bad of a deal. I was already thinking tandom axle and breaks so sounds like I was on the right track. This will be a complete restore for me. Deck, carpet, seats, rebuild motor, helm, rewire, upgrade electronic. It should be fun.
  #6
Old August 26th, 2006, 07:43 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
sound like a fun project.. i've always want to do one.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What is the largest length boat you can still trailer? poormonkey Boat Topics and Questions (not engine topics) 15 February 16th, 2005 11:48 PM
Pontoon boat move: trailer needed samblane Trailers and Towing 1 October 7th, 2004 11:59 AM
Pontoon boat trailer , whats it worth ??? cootersplace Trailers and Towing 11 October 17th, 2003 01:38 PM
Getting A Pontoon Boat Out Without A Trailer Stevehood1 Trailers and Towing 7 September 19th, 2002 01:25 PM
24' Monark Pontoon boat Trailer catfisher Trailers and Towing 2 January 10th, 2002 03:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
