tashasdaddy said:were you getting good water flow from tale tell. no alarms,
Thank you,going to check tomorrow and get back with you.once again thank you05GlastronSX said:yes he does mean the pee hole. the tell tale is just a proper name...check spark and compression and go from there
MortenH said:And check the fuel line and primerbulb. Is the bulb hard? Does the engine run faster with someone pumping the bulb?
-M-
05GlastronSX said:you need to rebuild your fuel pump...
Checked compression,spark,fuel line,rebuild fuel pump and all three carbs.Think it might be stator going bad? Going to check soon as I learn to understand OMS reading.skhourey said:05GlastronSX said:you need to rebuild your fuel pump...
1981 mercury 115 SN.5922192 model115ELPTskhourey said:1981 Mercury inline 6 115HP.
Pulling tub yesterday running great, all of the sudden horsepower, droped to about 5mph.Sounds good,no missis,just don't want to go fast.Starts right up,idles fine.Please help8)
skhourey said:1981 mercury 115 SN.5922192 model115ELPTskhourey said:1981 Mercury inline 6 115HP.
mudcarp here,with futher checking I noticed fuel running out of the top carb throttle shaft (enough to wet the inside of the motor but not spraying out) all the way down through number 2 through number 3 and out the bottom is this normal.just rebuilt ran finecouple months.Thank you
skhourey said:skhourey said:1981 mercury 115 SN.5922192 model115ELPTskhourey said:1981 Mercury inline 6 115HP.
With futher checking throtle shaft leake after I shut off motor for a while not when motor is running
