The Starboard o-temp warning sensor goes off after about 5 minutes running on the muffs at idle. ~ 900 RPMs. My OMC manual does not tell you how to get the sensor out. Do I need to order a head gasket and pull the head to get to the sensor and install a new one? I can count about 2 seconds with my finger on the head on each side before it's too hot to hold. Port side is OK. Same temp to the touch, ~ 2 secs.
Thanks,
John
Thanks,
John
