Re: 1985 Evinrude starter problem
Start with a known good battery fully charged, clean tight connections at battery terminals, engine block ground, solenoid and starter. Measure the voltage from the starter positive post to ground with the key engaged...if you get 12V (or very close to battery voltage) then starter's bad. If low voltage at the starter, measure voltage from the solenoid input terminal (small post with red or yellow/red wire) to ground. If low voltage at the solenoid, troubleshoot ignition switch, neutral safety switch and wiring harness. Otherwise replace solenoid.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
