  #1
Old August 21st, 2006, 06:13 PM
JSchaumleffel JSchaumleffel is offline
Default 1986 Yamaha 150ETLJ No Tilt/Trim in forward gear?
Took the boat out today and noticed that the motor would not tilt or trim from the throttle lever. When in neutral or in reverse it works fine. Also, the tilt/trim switch at the motor works no matter what.
I've taken the 703 control apart and checked everything as well as connections, etc. at the motor. I did not seem to find anything wrong.
Any suggestions or knowledge where to go next?
  #2
Old August 21st, 2006, 10:40 PM
rodbolt rodbolt is offline
Default Re: 1986 Yamaha 150ETLJ No Tilt/Trim in forward gear?
check for continuity between the red and blue trim swtch wires with the up button depresed and while wiggling/twsiting the switch harness. sounds like a wire is broken.
  #3
Old August 22nd, 2006, 08:45 PM
Quote:
Sure enough! I took the 703 control apart again and took the t/t switch out and when moved around, it would work. Found a broken wire where the harness wraps through the handle. Thanks for your help, a new switch is ordered and is on the way!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 1986 115 V4 Trim Tilt JohnSW Yamaha & Suzuki Outboards 2 June 20th, 2006 11:35 AM
40 Yamaha Long Shaft 1985 UK Model - no forward gear thebigman Yamaha & Suzuki Outboards 0 January 29th, 2006 03:34 AM
Yamaha 200 hp 1986 tilt trim electrical abbe1 Yamaha & Suzuki Outboards 1 July 23rd, 2005 11:15 AM
1986 Yamaha 115 tilt/trim Happy Lizard Mako 224 Yamaha & Suzuki Outboards 2 April 12th, 2005 08:04 AM
1986 90 hp Trim and Tilt Fortech Mercury & Mariner Outboards 5 February 23rd, 2005 06:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
