  #1
Old August 21st, 2006, 05:37 PM
Theoutdoorsman's Avatar
Theoutdoorsman Theoutdoorsman is offline
Default 1979 Evinrude 140 hp powerhead rebuild questions?
Sorry to double post this question guys, but my other thread appears to be stagnant. Does anyone know of a trick to installing the retaining rings in the pistons without the use of the Special Tools Cone and Driver? Any tips or tricks would be much appreciated. Thanks in advance...................ALAN
  #2
Old August 21st, 2006, 08:33 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: 1979 Evinrude 140 hp powerhead rebuild questions?
You can do it by hand with the help of a very small screwdriver or a pick. Make sure they are completely seated in the groove. Watch your eyes.......
  #3
Old August 21st, 2006, 10:58 PM
Watch your eye's.........LOL........been there done that. Twice now, I've had to go looking for one. d
Now that the clips are inserted in one of the pistons, I've got 1 more question and one concern............ first the concern:
CONCERN: When installing the clips I ever-so-slightly nicked the outside piston wall, around the wrist pin holes, with the ends of the clips themselves. It appears almost impossible to get them into the groove without some type of scratch being present afterwards. Seems minor, but I'm certainly no expert at this either. Please tell me I didn't just screw this up at the very beginning of the rebuild and lose a pint of blood from a stab wound via my pick for nothing.
QUESTION: When they returned my crank, I noticed they had removed all 6 of the seal rings, placed them in a bag, and shipped them back to me, still seperated from the crank shaft. Now I have no idea as to the proper placement of the seals. How do I know where they were before shippment? I didn't realize they'd remove them, or I'd have done so myself and labeled everything.
  #4
Old August 22nd, 2006, 04:06 PM
Had to hold up on rebuilding to wait for two new correct size wrist pins to arrive tomorrow morning. Seems they packaged the wrong size with two of the kits. Can anyone answer these questions? Am I finished before I even get started? I'm going to check for clearance on the crank seals to make sure I'm within speck, as per the service manual, while I'm waiting on the wrist pins. If the piston scratching is a common thing, can I go ahead and pop 2 of them in, put the crank in place, and slide the other 2 rods/pistons in later? Or should I hold up right here until the correct wrist pins arrive and only then proceed with the insertion of the crank shaft? Thanks..................ALAN
  #5
Old August 22nd, 2006, 04:23 PM
The scratches on the piston can be cleaned up with a Scotch Brite pad or emory cloth. Nothing to worry about.
Same with the seal rings, it doesn't matter about the order, they're all alike. Don't worry about measuring anything. OMC discontinued the oversize rings long agao. We're more concerned thet they move freely rather than the actual fit.
You can go ahead with getting the crank in the block if you like.
  #6
Old August 22nd, 2006, 04:28 PM
Just a thought -- when you go to install the clips, install one before you put the pin in. Stick it in with the gap end to you. Once it's in use the screwdriver or whatever to flip it and it should pretty much pop in the groove once it gets close. Just make sure to get the gap end anywhere except at the notch.
  #7
Old August 22nd, 2006, 06:48 PM
I accidently warped one of the clips, but I took the clip back out and reshaped it with a pair of needle nose pliers. It appears to fit just fine now. Does the clip need to be replaced, or am I good to go, so long as it conforms to the groove in the piston and has a nice tight fit with a "snap" in place? The seal rings are now back on the crank. Thank you a bunch for the info. Also, I recieved the wrist pins today. Seems Wiseco agreed to pay for next day air delivery of my proper pins. If you could give me a pointer or two on installing the seal in the lower crank case head, I might possibly make a lot ground tonight. That's all that is keeping me from getting this thing off the ground, with the exception of the wrist pin clip of course. Again, many thanks to you for the excellent info you've offered...................ALAN
  #8
Old August 22nd, 2006, 08:51 PM
sand716 sand716 is offline
I need advice on the best way to part out a 1972 65hp evinrude electric shift model 65273S (yes, it's a 1972). I overheated it and I think it's only running on 2 of the 3 cylinders. I need to get the most out of it so to replace it. Any suggestions. Looks like ebay will only fetch low end prices for the parts. Any suggestions would be greatly appreciated. I kinda got taken when I bought it. email or even call. I need help getting the most. 817-795-5840. Thanks and god bless. Darrell
  #9
Old August 22nd, 2006, 09:03 PM
Replace the clip. Period. If it's a Wiseco piston, use a Wiseco clip, not an OE.
  #10
Old August 22nd, 2006, 09:41 PM
I'll check with some local dealers and see if I can locate a clip first thing tomorrow morning. However, tonight, I'd like to get this crank in. Then I'll feel good about today's progress. So far, everything has gone rather smoothly.........and slow going. I'm trying really really hard to take this slow....... d ......... Seems easy to just take off....... LOL .........If you can give me a pointer or two on getting that seal in, I'll get that crank in and wrap things up for the night. Thanks a bunch.............. ALAN
  #11
Old August 23rd, 2006, 08:48 AM
The lip goes down. Press on the flat side.
If the local guys don't have a Wiseco clip send me an email at dhadley50@aol.com.
  #12
Old August 23rd, 2006, 09:57 AM
Are you saying this isn't the correct position of the seal? I still don't have it seated as of yet, so it can be repositioned. If this is indeed the case, it was installed backwards before I started this rebuild. Hmmmm.........Thanks.........ALAN
  #13
Old August 23rd, 2006, 10:53 AM
I need an expert opinion on this.............use it or trash it? Mar-Fab has repaired the head and says it should be OK for use. I just have a hard time believing I should continue using it. But then again........I've been wrong before. What do you think?
  #14
Old August 23rd, 2006, 06:35 PM
The seal will work that way but it's supposed to go the other way. Now, here's one for you -- the lower cap on the early 3 cylinder and 2 cylinder are the same. The ends of the crank is the same. The book calls for one to go in lip down and the other to go in lip up. Beats me, both ways work.
Hummmmm.......I wouldn't use that head but that's just me. It wouldn't surprise me if it was OK and lasted many years but I think I'd have a hard time bolting it on.
  #15
Old August 23rd, 2006, 10:54 PM
My thoughts exactly on the head. As far as the crank head seal goes, I think I'll go on and press it in as is then, or maybe I'll turn it over.........hmmmmm???? .......... If I leave it as is, the lips of the seals will face each other. And the last seal seems as though it did it's job very well. I think I just answered my own question, huh? I'm going to take a rookie chance here and press it on in as is. Although, it would be easier to put in if it were turned over. I guess that's what had me puzzled in the first place. Oh well, if it really doesn't matter, it's going on in like the last one. Here goes nothing................. Thank you again!!!!.................ALAN
  #16
Old August 24th, 2006, 08:37 AM
If this is a 79 crank and cap, there's only supposed to be one seal in there.
  #17
Old August 24th, 2006, 08:38 AM
Oh, and make sure you have new O rings on the 4 ss screws in the cap.
  #18
Old August 24th, 2006, 08:46 PM
Quote:
Is the part number on these "O" rings 332585 ?
I have noticed the seals on the screws when I took them out, but there is no mention of these seals in the service manual. Wonder why?
As far as the crank seals, I was referring to one on each end of the shaft. Don't scare me like that.......... d
  #19
Old August 24th, 2006, 09:33 PM
The top seal has to go in lip down.
Yes, that's the O ring number for the 4 ss screws.
  #20
Old August 24th, 2006, 09:56 PM
Thanks for the verification on the "O" rings. I had a hunch that is what they were for, but I was really beginning to wandering. As I said before, there is no mention of them in the manual during the crank shaft installation section. Hmmmm? As for the lower crank shaft head seal, I've already seated the seal like it was in the picture above. Maybe I misunderstood you, but I thought you said it really didn't matter? After all, this is the way it was positioned when I took the old one out. Do you think it will be OK as is? I'm certain it can't be taken out and turned over as this will likely cause serious damage to the seal. Thanks!..............ALAN
P.S....... I have updated the photo to show a closer, and clearer, view of the seal and head. You may have to refresh your browser to view the NEW picture.
  #21
Old August 25th, 2006, 08:32 AM
I've seen them in both ways on the bottom cap. Obviously if it was that way before, it'll be OK now.
  #22
Old August 25th, 2006, 09:54 PM
As for the ss screw seals, are they supposed to be place on the screws prior to sliding them through the crank case head and threading them into the bearing retainer plate? I would assume they would, but since there is no mention of them, I suppose I should be absolutely possitive on their correct placement before hand.
  #23
Old August 26th, 2006, 09:57 PM
I recieved the clips you sent me today!!!! The last piston is in, heads temporarilly installed, and block ready for crank shaft installation. The only hold up is the verification on the correct placement of the seals on the stainless screws that go in the lower crank shaft head assembly. Am I correct, in that they go between the screw head and crank shaft head? Thanks a bunch!!!................ ALAN
  #24
Old August 27th, 2006, 12:23 AM
Quote:
Originally Posted by Theoutdoorsman
I recieved the clips you sent me today!!!! The last piston is in, heads temporarilly installed, and block ready for crank shaft installation. The only hold up is the verification on the correct placement of the seals on the stainless screws that go through the lower crankcase head assembly. Am I correct, in that they go between the head of the screws and the outside of the crankcase head? Also......... and I hate to bring this up........ should I, or should I not, apply oil to the connecting rod cap screws before I torque them? The service manual says yes, but others here on iboats say not to. Just curious as to what you would recommend or what has worked well for you in the past. Thanks a bunch!!!................ ALAN
  #25
Old August 27th, 2006, 10:09 PM
Obviously Dale is really buisy. Can anyone out there help me out with the correct placement of these seals? Much appreciated..............ALAN
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 evinrude 235hp powerhead rebuild.Help?? blane Johnson & Evinrude Outboards 9 December 9th, 2006 01:37 AM
1979 Evinrude 140 carb rebuild? Theoutdoorsman Johnson & Evinrude Outboards 11 September 5th, 2006 09:51 AM
1979 Evinrude 140 rebuild..........almost ready !!!!! Theoutdoorsman Johnson & Evinrude Outboards 0 July 31st, 2006 11:12 AM
1979 Evinrude 140 rebuild ? Theoutdoorsman Johnson & Evinrude Outboards 1 July 1st, 2006 08:00 AM
1971 evinrude powerhead rebuild captain spike Johnson & Evinrude Outboards 2 March 20th, 2003 08:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
