VikingHoops
- May 18, 2004
- 2
Hey guys! I have an 88 Four Winns I/O 6Cyl OMC
I have had trouble starting this summer. Have to crank it a while before getting it to fire. Finally got stranded last weekend and determined no spark from coil. Replaced coil and it starts fine now.
Problem I have is not getting good connection at the battery. I removed the battery and noticed a few things.
1. Wing nut screwed off hard on Neg terminal (screwed on easy when I last put it on)
2. Plastic on battery case under Pos & Neg terminal look melted
3. Plastic on Neg Wire near post looks melted.
I assume that my battery is bad (5 yrs old), but question I have is did the faulty battery cause the coil problem or is something else causing my battery problem?
