  #1
Old August 20th, 2006, 11:22 PM
yelladog yelladog is offline
Default 1973 Evinrude 25 (Upper Crankshaft Oil Seal) &
Just wondering if it is a big project to change the upper crankshaft oil seal. I also have a suzuki and its not much trouble. Just a matter of removing flywheel, stator assembly and a plate that has the seal in it. Noticed on this motor it doesnt look so easy. Thanks Alot
  #2
Old August 21st, 2006, 02:04 PM
Default Re: 1973 Evinrude 25 (Upper Crankshaft Oil Seal) &
Quote:
  #3
Old August 21st, 2006, 02:05 PM
Thoughts Anyone?????
  #4
Old August 21st, 2006, 03:43 PM
Paul Moir Paul Moir is offline
OMC made a seal puller that you could thread into the seal an pull it out. Picture a tapered piece of pipe that was threaded. You would thread this into the old seal over the crankshaft and pull it out like a wine cork.
In the absence of the puller, use this technique I learnt from OBJ. Drill a couple holes in the metal part of the seal, and thread in a pair of small sheet metal screws almost all the way. Then use the screws to pry the old seal out using a slot screwdriver.
Either way is far easier than disassembling the engine.
  #5
Old August 21st, 2006, 04:09 PM
Thanks Alot, That sounds like a plan. I'll give it a shot and your right, it has to be easier than spliting the crank case.
  #6
Old August 22nd, 2006, 12:00 AM
R.Johnson R.Johnson is offline
Keep in mind that if you pry on the magneto bearing boss that surround's that bearing, and seal, and is only about 1/8" thick, if you break it, you are looking at an entire engine block. If it is not leaking, leave it alone, or take it to a dealer. I have seen more than one of them broke off with a make shift attempt.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
55HP Upper Crankshaft Seal Replacement drhulv Johnson & Evinrude Outboards 2 September 3rd, 2005 09:25 AM
1962 40hp evinrude upper crankshaft seal ? jmc03021013 Johnson & Evinrude Outboards 3 April 24th, 2005 11:45 AM
Evinrude 115 crankshaft seal Paul Witt Johnson & Evinrude Outboards 3 July 16th, 2003 04:32 AM
Mystery ???upper cyl. crankshaft seal 18 hp web_runner Johnson & Evinrude Outboards 4 July 14th, 2003 08:03 PM
'60 Evinrude 18 crankshaft seal Fontanaman Johnson & Evinrude Outboards 4 September 4th, 2002 04:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
