  #1
Old August 20th, 2006, 02:30 PM
sharkman sharkman is offline
Default 2hop Evinrude (4206s) ignition problems
Hello- I have been working on this engine over the last few months which I was told had not been used for 20 years or so. I got it running fine but a few weeks back I had it up at the lake and was running it a full throttle when it suddenly stopped. Now I cannot get it going again and have no spark.
What's up....how can I tell if it is the coil, condenser points etc. or do I replace all?
Thanks
  #2
Old August 20th, 2006, 03:29 PM
Paul Moir Paul Moir is offline
Default Re: 2hop Evinrude (4206s) ignition problems
Pull the flywheel. See if the flywheel key is broken. If not, clean and gap the point .020") and see if it sparks again. If the points' contacts are burnt, replace them and the condensor too. If the contacts are covered in oil, look at the top main crankshaft seal (if it's got one). If that all checks out, make sure the ignition coil's insulation is not cracked. But I think that's least likely the problem here.
I think the flywheel nut torque on that one is 20-25 ft/lbs.
  #3
Old August 20th, 2006, 03:49 PM
10-4 Paul
Thanks once again
  #4
Old August 20th, 2006, 06:23 PM
okay - cleaned the points, reset the gap to .20 and now have fire
even when i set the tester at 3/8" - great spark
problem solved and many thanks Admiral
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
4 hp evinrude (4206s) exhaust/cylinder head gaskets sharkman Johnson & Evinrude Outboards 2 September 9th, 2006 10:44 AM
Hey Joe, my 200 evinrude has ignition problems po-it Johnson & Evinrude Outboards 4 September 21st, 2004 04:23 PM
82 Evinrude 115 ignition problems?? gt1878 Johnson & Evinrude Outboards 0 June 1st, 2004 07:38 AM
Evinrude XP 150 Ignition Problems vaughan376 Johnson & Evinrude Outboards 4 January 25th, 2004 05:04 PM
Evinrude XP 150 Ignition Problems vaughan376 Non-Repair Outboard Discussions 1 January 25th, 2004 07:29 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
