Re: how to know if accel pump is working right?
a lot depends on what carb you have. If its a 2 barrel then you don't have secondaries. Secondaries are on a 4 barrel carb.
when you push the throttle from idle to wide open, the accelerator pump is supposes to shoot a certain amount of fuel. Depending on the carb, it can be anywhere from 10-50 cc's which is only 2 ounces or less. Not practical to measure it, if you see a healthy directed squirt of raw fuel from the pump nozzle then it's fine. If the squirt is flaired out the nozzle or has a spray then you either have blockage in the passagway or nozzle that needs to be cleaned out, or the accel pump mechanism needs some work. If the motor is popping when reving it in neutral then it is not the accelerator pump.
