Re: Boat pulls and leans to left...
All single propeller systems exhibit some torque to the opposite side of the propeller rotation. If the boat is level, completely loaded, and not underway, then she will list to port under power. One solution is to load her a little heavier to Starboard. This is automatic when you are alone as you, your ownself, are the counterbalance
New or otherwise, IMHO you should add Bennett's or another adjustable tab system. I believe they should be standard on all v-hulls and you will find many more reasons to like them other than the ability to balance loads at different speeds.
Edit: As far as pulling to port is concerned. Does your drive have a small vertical trim tab (fin) just below the ventilation plate and immediately above the propeller? If so, that can be adjusted for the pull, but it will probably move the symptom to another RPM instead. Your owners manual has information on how to adjust it . . .
