  #1
Old August 17th, 2006, 02:24 PM
Mav23rick Mav23rick is offline
Default 40 Hp 3 cyl Mariner 1998 Power loss after approx 30 minutes of use
Mariner/Mercury 40 HP 3cyl E. 1998. Plugs good, gas good, fuel pump OK, filter replaced... Looses power after initial good performance at full speed, (30 to 40 min.). Upon the next start-up, the motor will go to full power. While the motor is at full throttle an running slow, I push in the electric chock in and get an initial burst of power then back to slow speed. I've pumped the gas bulb with no effect. I have not done the heat test with a dryer. I was just wondering if anyone can tell me what they did to correct their problem?
Thanks, Mav...
  #2
Old August 17th, 2006, 03:04 PM
Default Re: 40 Hp 3 cyl Mariner 1998 Power loss after approx 30 minutes of use
CORRECTION:
Upon the next start-up, the motor will "NOT" go to full power...
Can anyone help? I've got twin girls that want to ride a tube...
  #3
Old August 17th, 2006, 03:35 PM
Me Again... I have the exact described problem as JP:
Problem: motor runs great at various throttle positions including full speed (5000)rpm for 10 - 20 minutes or so after initial startup but then suddenly cuts back to about 3400 rpm at full throttle. Once the motor starts this behavior, it will not run at full rpm (5000)without coaxing. I did discover that the engine will run at 5000 rpm if I manipulate the electronic push button choke intermittently.
Can anyone help?
  #4
Old August 17th, 2006, 08:31 PM
Texasmark's Avatar
Texasmark Texasmark is offline
I had a '75 70 hp OMC that did that and it turned out to be the thermostat sticking closed. You could start it and run it for the first few 10's of minutes and it was a darlin but after awhile it started running rough and wouldn't perform the same.
Finally, one day, at WOT it froze shut. Cost me an overhaul.
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power loss after approx 1 hr of running Sea Ducer Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 11 April 29th, 2006 02:56 PM
1998 Yamaha 200 EFI Power Loss swensoc Yamaha & Suzuki Outboards 1 July 25th, 2005 10:00 AM
1998 merc 75hp - loss of power stanois Mercury & Mariner Outboards 3 June 13th, 2004 07:21 PM
Yamaha F9.9B power loss 1st 15 minutes vosljouwert Yamaha & Suzuki Outboards 0 May 7th, 2004 10:52 AM
1998 150 CARB. V-MAX LOSS OF POWER MITCH WELCH Non-Repair Outboard Discussions 14 October 17th, 2001 05:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
