Weight of 19' Grady White Tournament?
greentahoe
What is the weight of a 19' Grady White Tournament with motor? Will a single axle trailer handle one well?
Thanks
tashasdaddy
Re: Weight of 19' Grady White Tournament?
go to nada click boats, and follow prompts, find your boat, it will show dry weight. this is as it came from the factory, without your add ons, and gas. if you have an outboard you can find it and it will have wt. of motor.
fay62664
I have a 1992 Grady Tournament 190 (not 192 ) centerline 18'11" weight with out Engine I believe is 2075. If you go to www.gradywhite.com you can look at past year brochures with specifications. In skimming literature I think I spotted a 200-400lb swing between model years.
A 2 Stk 150 Yamaha is approx 450lbs.
dingbat
That boat could easily go #3200 when loaded with equiptment and fuel.
I had a Grady Overnighter (20') and the boat/trailer combo went #5230 on the local truck scale.
fay62664
Dingbat, I have been planning to take my boat trailer to local recycling facility to get a weigh in with all the gear. Thanks
