imported_timt
- Jul 15, 2006
- 5
First time post and not much of a mechanic. My 70hp evinrude starts and sounds like it is running on one cyclinder. After checking compression ( good) , replacing fuel lines,gas tank, filter, and plugs (champion) it is still doing it. Starts up and revs up, but under a load it feels like it's only a 15hp. Today I started looking at the carbs and pulled the drains on the bowls. Top carb drained gas, middle and bottom carb did not. I then left the drains open on the carbs and pumped the ball on the fuel line. Gas only came out of the top carb.
So here's my question, when the drains are open on the carbs (all of them at once) and you pump the fuel line bulb, is there gas supposed to be comming out of carbs drains ?
Am I going to have to pull the carbs off and rebuild ?
It all started when I used Penzoil fuel stabilizer.
Is there any chance the fuel pump is shot and how do you check for a faultly fuel pump ?
Any help is much appreciated.
Timmy
Timmy
