white smoke or steam?
waterdawg69
i have noticed once my engine has wammed up there is white smoke comming from exhaust. or could it be steam. what causes this thanks for any help.
QC
Re: white smoke or steam?
I/O, inboard, O/B? What type of exhaust setup? In almost all cases water is run through the exhaust to reduce the risk of fire and to cool components in a marine application. Water mixed with hot stuff = steam . . .
What your seeing could still be smoke, but that would take a visual. If it dissipates like steam, then it probably is.
waterdawg69
well it kinda lingers a little but the humidity is high here. but its a 160 hp merc. i/o.
wvit1001
White smoke would be steam or a little oil burning. Black smoke usually means excess fuel.
QC
Well if it lingers, and you can still see it after 10 seconds or so, I would agree with wvit1001 and it sounds like you are burning some oil . . . Does it use any oil?
wvit1001
I've got a '95 Stingray with a 350. It blows just a very little white smoke when it's first started but after it warms up and the motor tightens up that goes away.
