  #1
Old August 13th, 2006, 10:39 PM
gungalunge gungalunge is offline
Default Mercury 115 1974 Lower unit Jammed in reverse
The Other day comming into the dock i shifted into reverse to avoid bumping another boater pulling out .I was sucessfull . But my shifter jammed . It racheted the lower end did kind a lot .Then a clunk. I took the lower unit off . The shift shaft dont move . Either way ..I am Going to attempt the lower end rebuild . Its not apart yet . I got a list of parts gathered I suspect that I broke that clutch .I better just rip it down and see what happened . New seals bearings and clutch parts seem to be availble . i sure hope the gears are all good any suggestions . I read the manual and see what is ahead .. I see that the basic parts list out to 250 bucks with shipping . lots of pressing off bearings . Has anyone attempted this with out all the special tools ???
  #2
Old August 14th, 2006, 12:56 PM
MortenH MortenH is offline
Default Re: Mercury 115 1974 Lower unit Jammed in reverse
I have resealed the LU on my 1984 115 I6 without special tools, it was not very easy but it is possible to do. I also replaced all the gears with parts from a spare LU. I did not have to remove the bearings though. The biggest problem was to get the bearing carrier assembly out. I used a set of wooden chisels to get it out.
-M-
  #3
Old August 17th, 2006, 01:48 AM
I got it apart I ordered a whole mess of parts i needed .I am now doing each segment . I did the whole upper power head this spring and wow is all i got to say .until i jammed the lower unit which i did not rebuild thinking it was good . turns out that my pinion nut backed out . "it did not fall off got it in time" the shift cam and rods are wasted.the cam follower clutch and gears both knicked up . the parts are comming 250 bucks for seals and bearings .150 bucks for shifter linkage parts .. I am doing the press work and those bearings are all shot so far .i am making tools and cutting off stuff left and right .this 32 year old motor .is a challange But I will win the war . I think since I went this far I will replace the gears . with new ones allthough the old ones are not that bad .
  #4
Old August 17th, 2006, 10:50 AM
Texasmark's Avatar
Texasmark Texasmark is offline
Remember your powerhead rebuild. Now you have a new motor. 8)
Good luck,
Mark
  #5
Old August 20th, 2006, 01:17 AM
wow tex i got into a new beast . the lower end for me .right now i pressed off all the bearings looked at them .. shoot when i did the engine I should of got in there too .. I am having a hard time finding a shift cam . the reverse gear bearing was scrap ,my pinion nut was loose . the gear lube was stinky . I am all over it . If i can get ahold of a shift cam i would love it .yep the motor is a jewel but this lower is getting the trick too. right now gathering the things i need . buying them right here on i boats 32 year old motor getting closer to new . the tools i explaned being in need of i had in my tool box so far so good . this next week i should be on the lake again if i can get a shift rod and a cam .i still dont have the amd rules wake but a good photo of what goes on in the back will be my happy day
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1970 Mercury 650, No reverse after dropping lower unit revcu Mercury & Mariner Outboards 4 May 15th, 2003 06:31 PM
1970 Mercury 650, no reverse after lower unit dropped revcu Mercury & Mariner Outboards 4 May 15th, 2003 06:11 PM
1970 Mercury 650, No reverse after dropping lower unit revcu Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 May 15th, 2003 04:24 PM
1974 85hp Mercury lower unit (help) justingregfavorite Mercury & Mariner Outboards 1 January 6th, 2003 02:12 PM
Mercury 850 (1974)/ Reverse problem texas15 Mercury & Mariner Outboards 3 June 16th, 2002 12:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
