tashasdaddy said:measure from the transom mount to the anti plate just above the prop. flywheel: you will need a harmonic balancer pulley(do'not use the 1/4' bolt that comes with it) get 1/4x20 #8 strength bolts , the original bolt wiil strip out. position the center bolt over the crankshaft, install the 1/4 bolts so the are completely thru but not far enough to da,age anything under the fly wheel. thighten the center bolt prteey tight. a couple of raps on the center bolt and tighten agaim repeat, repeat. and all of a sudden POP. be sure when you replace it to use a new woodruff key and my manual say the torque should be 480-540 inch pounds not foot pounds. if you don't torque youwill shaer the woodruff key.
