  #1
Old August 12th, 2006, 12:46 PM
*chris* *chris* is offline
Default 1986 40hp Yamaha, should it charge the battery?
I have an engine which seems to be the combination of a 1989 6H4 L 558276 - 40etlf (lower unit, bracket with electric tilt, and cowling) and a 1986 powerhead. I spent some time on the phone with Yamaha support and this is what we came up with the serial numbers on the block and bracket and the model numbers.
Anyway, should this electric start motor charge the battery? I have the 1986 shop manual and can't seem to figure it out. When running it currently does not charge the battery.
My other question is does this motor require a converison box to run a tach and what is the model number of the unit, it is not listed in the shop manual either. It just shows the green, black and blue wires connecting directly to the tach.
Chris
  #2
Old August 15th, 2006, 10:21 AM
Ray Neudecker Ray Neudecker is offline
Default Re: 1986 40hp Yamaha, should it charge the battery?
Yes it should charge the battery, but will not handle large loads or deep cycle batteries. It also does require the conversion box for the tach.
  #3
Old August 23rd, 2006, 04:42 PM
Ray:
Thanks, what I found out was the rectifier was "shorted out" as both inputs were connected to the same green wires coming from the lighting coil. I reconnected the rectifier properly and now the battery seems to be charging. I have an 85 amp hour deep cycle battery and while idling the battery voltage slowly comes up. i.e. at rest the battery reads 12.7v and while the engine is running it reads 12.8v and slowly going up. I am used to seeing around 13.4v when an engine is running and charging, as you said in your earlier post, is this battery too large which is lowering the output voltage of the rectifier?
As to the tach conversion box, can you point me to a link to the device? Is it made by Yamaha? By looking at the wiring diagram, it seems that this green wire that goes to the rectifier is the same wire used by the tach?
Chris
  #4
Old August 23rd, 2006, 10:11 PM
Good news, went fishing tonight and watched the voltage on the battery go up to 14.1v, we are charging! Now if I can get the tach sorted out I will be all set.
Chris
  #5
Old August 24th, 2006, 10:19 AM
The tach converter assy is a Yamaha part. When using a deep cycle battery, the amperage to charge if low is too great for the system. By being sure the battery is fully charged before using, you should not have a problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha OX66 does not charge battery Wiscbw Yamaha & Suzuki Outboards 1 April 17th, 2006 04:48 AM
2000 Yamaha 9 HP 4 stroke pull cord to charge battery? DjPro Yamaha & Suzuki Outboards 2 June 1st, 2004 08:48 AM
1986 45hp Mariner doesn't charge battery perdidojoe Mercury & Mariner Outboards 2 May 29th, 2004 10:28 PM
1986 Yamaha 40HP Questions tgarrity Yamaha & Suzuki Outboards 1 August 13th, 2003 11:57 AM
Does 40HP Johnson Charge Battery IBFISHIN Johnson & Evinrude Outboards 2 November 1st, 2002 04:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
