  #1
Old August 11th, 2006, 09:31 PM
Bert Bert is offline
Default Seized piston 175 Evinrude
I have a 1995 Ocean Pro 175 with a seized piston.Looks like it got water in one of the cylinders. What would be the best way to remove the piston. I have removed the heads and put the motor in gear and tried to turn it by hand. Can't get it to move.
  #2
Old August 11th, 2006, 10:06 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: Seized piston 175 Evinrude
Is it #1?
  #3
Old August 11th, 2006, 11:01 PM
Solittle Solittle is offline
Tilt the engine up, put it in neutral and put a couple of tablespoons of Marvel Mystery oil in each cly. Let it sit for a day or two. Take a socket wrench to the nut on the top of the crank and see it it will turn. It may free up.
  #4
Old August 12th, 2006, 12:49 AM
AlanR AlanR is offline
or pull the plugs out and put some diesel fuel in the cyclinders and try and turn the fly wheel each day till it gets free. diesel fuels cheaper and works just as good
  #5
Old August 12th, 2006, 09:48 AM
Silvertip Silvertip is offline
Be very gentle with the turning attempts. If you attempt to force it free you run the risk of breaking rings and ring lands. Just rock the flywheel back and forth within the limits of travel. Insert more diesel fuel and let it sit a couple days. Repeat the process as necessary. When free, it would be a good idea to remove the head to see what damage if any was done. Generally there is piston scuffing and cylinder bore damage.
  #6
Old August 12th, 2006, 01:00 PM
The heads are off. # 5 is seized, it's at the top of the stroke so I can't see the cylinder wall. Will keep adding diesel each day. Thanks for the replys.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude 50hp seized, lack of oil surferweller Johnson & Evinrude Outboards 5 April 7th, 2007 08:30 PM
seized piston dcfrank Mercury & Mariner Outboards 1 March 13th, 2006 09:41 AM
140 Evinrude - broken piston ring, piston expansion? andys15 Johnson & Evinrude Outboards 23 July 25th, 2005 08:42 AM
1986 Evinrude 225, seized up..sort of. GCasas Johnson & Evinrude Outboards 6 May 13th, 2005 01:06 PM
25hp 1972 Johnson Sea Horse, flywheel seized, prop seized, stuck in neutral BrushWolf Johnson & Evinrude Outboards 2 July 22nd, 2002 04:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
