Re: Evinrude 4 2 cylinder
Resist the urge to hammer on the shaft. The proper way to remove the flywheel is to use a 3-bolt puller that utilizes the three threaded holes in the flywheel. You can get such a puller at auto parts stores, called a vibration damper puller. Important---also get three grade 8 bolts to go with it unless you like to remove broken bolts. And don't waste your money on the flimsy cast aluminum pullers that are out there--get a good steel one. When you reinstall the flywheel, the shaft and flywheel tapers must be clean and dry. Use a torque wrench to tighten the nut to 40-45 ft/lbs. Now that you know how to do it, do it right!!
