1966 60 hp evinrude motor mod# 60653R
joesboat
i have a 1966 60 hp evinrude motor on a 15 or 16 ft. larson boat. the previous owner messed up all the wiring. there is a electric starting box ( where the soleniod is) all wires are connected to the 4 terninals. I need to know how to run the wires from the fuse panel ( where the little glass buss fuses are). how to run the wires from the toggle switch ( for port/star lights and for white stern light).how to run wires for blige pump to toggle switch. how to run new key ignition (with a choke) and where does the fuse go between all these wires? can someone draw or send me a SIMPLE diagram so i can get started. any little bit will help because once i get started i can get the rest. I know all about the correct guage wiring,amps.etc.
