  #1
Old August 9th, 2006, 10:29 PM
marty5030's Avatar
marty5030 marty5030 is offline
Default Compression for 1990 Evinrude XP 150
I am buying a 1990 Champion with this Evinrude XP 150 on it. Owner says runs well and no problems. I had it compressioned checked and found that 2 cylinders had 95, 2 more had 90, 1 had a 100, and 1 lower cyl had an 85.
One mechanic thinks this is just a tired motor and should be fine. I am not sure if motor was at temperature or decarbed recently. Also this was done 6 years ago by owner with very similar numbers.
Any help would be awesome...hopefully this will be my first bass boat unless these numbers are not good.
__________________
Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise.
  #2
Old August 9th, 2006, 10:56 PM
ob ob is offline
Default Re: Compression for 1990 Evinrude XP 150
I might be a little concerned with the 85 psi hole,however readings in the mid 90's to low 100's are typical on V-6 carbed two stroke John/Rudes.Another factor is the procedure used in obtaining the numbers you posted and the accuracy of the compression guage.
See if the guy is willing to perform a decarb on said engine and perform another test if you're concerned.
  #3
Old August 10th, 2006, 01:10 AM
MASTER Brian MASTER Brian is offline
I'd also suggest the decarb. I have a similar boat, mine is an 86 Ranger with an XP 150 on it. It ran great when I bought it and didn't do a compression test, but later I lost a cylinder, the others were all at 90 psi +/-.
I don't feel a compression test at time of purchase would have revealed anything as it ran fine for about 2 months before going down. I do think that a decarb might have kept the rings from sticking and later breaking, but I didn't know about it at the time. Looking back, sticking rings were what caused my occasional, but not frequent loss of power 2 times before she died.
Another thing, I'm not sure an expensive gauge would show much. It might give higher readings, but the main thing is that they are all w/in 10% of each other. If you are concerned about stuck rings causing low compression, I've heard of putting a tablespoon or so of oil in the cylinder followed by a compression check and seeing if it comes back up.
  #4
Old August 11th, 2006, 01:59 AM
marty5030's Avatar
ok, thanks for all the info!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
No Compression 1990 V6 4.3L Mercruiser swozi Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 April 27th, 2008 02:46 PM
1990 evinrude outboard compression mudcraz Johnson & Evinrude Outboards 1 October 25th, 2005 08:30 AM
1990 Evinrude E120TLESB no Compression #2 Cyl! Mullda162 Johnson & Evinrude Outboards 6 August 22nd, 2005 05:43 PM
1990 Evinrude 150 XP Compression #'s Spork Johnson & Evinrude Outboards 10 January 23rd, 2004 01:42 AM
1990 200 Evinrude - Good compression #'s mako17 Johnson & Evinrude Outboards 1 January 29th, 2003 02:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
